[GRASS-dev] latest change in v.surf.bspline breaks it on a Mac
Hamish hamish_b at yahoo.com
Tue Jan 13 15:24:27 EST 2009
Michael Barton wrote:
> I just updated develbranch_6 svn and compiled.
> v.surf.bspline will no longer compile. Lots of errors (or
> the same error many times.
> main.c: In function ‘main’:
> main.c:358: error: syntax error before ‘<<’ token
> main.c: At top level:
> main.c:370: error: syntax error before ‘==’ token
> main.c:373: error: initializer element is not constant
> main.c:373: warning: data definition has no type or storage class
it seems svn update had a conflict during the merge. in those cases
the files have the old/new bits which could not be merged like:
which the C compiler tries to interpret as code, and it fails.
Markus:
> Delete file + svn up should solve it.
Michael:
> That fixed it. Thanks.
and keep an eye out for any "C" conflict status files when doing svn up.
edit/fix and do "svn resolved filename.ext" (or rm file & svn update if
you don't mind abandoning local changes)
Hamish
