[GRASS-dev] Re: [GRASS GIS] #434: python swig bindings for 7.0 svn noyt working on ubuntu install
GRASS GIS trac at osgeo.org
Fri Jan 16 06:11:12 EST 2009
  Reporter:  mulligan  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  7.0.0
 Component:  Python    |     Version:  svn-trunk
Resolution:            |    Keywords:  python swig
  Platform:  Linux     |         Cpu:  x86-32
Comment (by mulligan):
 Hi
 Just updated to rev 35437 and still not getting the python_grass7.py files
 written
 here is the output of sudo make:
 Many thanks for any further insights
 Mark
 make /usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/etc/python/swig
 make[1]: Entering directory `/usr/local/src/grass_trunk/swig/python'
 make[1]: `/usr/local/src/grass_trunk/dist.i686-pc-linux-
 gnu/etc/python/swig' is up to date.
 make[1]: Leaving directory `/usr/local/src/grass_trunk/swig/python'
 gnu/etc/python/swig/_utils.so /usr/local/src/grass_trunk/dist.i686-pc-
 linux-gnu/etc/python/swig/_date.so /usr/local/src/grass_trunk/dist.i686-
 pc-linux-gnu/etc/python/swig/_grass.so /usr/local/src/grass_trunk/dist.
 i686-pc-linux-gnu/etc/python/swig/_math.so
 /usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/etc/python/swig/_proj.so
 gnu/etc/python/swig/_imagery.so /usr/local/src/grass_trunk/dist.i686-pc-
 linux-gnu/etc/python/swig/_vector.so /usr/local/src/grass_trunk/dist.i686-
 pc-linux-gnu/etc/python/swig/_raster.so /usr/local/src/grass_trunk/dist.
 i686-pc-linux-gnu/etc/python/swig/_display.so
 gnu/etc/python/swig/_stats.so /usr/local/src/grass_trunk/dist.i686-pc-
 linux-gnu/etc/python/swig/utils.py /usr/local/src/grass_trunk/dist.i686-
 pc-linux-gnu/etc/python/swig/date.py /usr/local/src/grass_trunk/dist.i686-
 pc-linux-gnu/etc/python/swig/grass.py /usr/local/src/grass_trunk/dist.
 i686-pc-linux-gnu/etc/python/swig/math.py /usr/local/src/grass_trunk/dist.
 i686-pc-linux-gnu/etc/python/swig/proj.py /usr/local/src/grass_trunk/dist.
 i686-pc-linux-gnu/etc/python/swig/imagery.py
 gnu/etc/python/swig/vector.py /usr/local/src/grass_trunk/dist.i686-pc-
 linux-gnu/etc/python/swig/raster.py /usr/local/src/grass_trunk/dist.i686-
 pc-linux-gnu/etc/python/swig/display.py /usr/local/src/grass_trunk/dist.
 i686-pc-linux-gnu/etc/python/swig/stats.py
 gnu/etc/python/swig/__init__.py /usr/local/src/grass_trunk/dist.i686-pc-
 linux-gnu/etc/python/swig/utils.pyc /usr/local/src/grass_trunk/dist.i686-
 pc-linux-gnu/etc/python/swig/date.pyc /usr/local/src/grass_trunk/dist.
 i686-pc-linux-gnu/etc/python/swig/grass.pyc
 /usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/etc/python/swig/math.pyc
 /usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/etc/python/swig/proj.pyc
 gnu/etc/python/swig/imagery.pyc /usr/local/src/grass_trunk/dist.i686-pc-
 linux-gnu/etc/python/swig/vector.pyc /usr/local/src/grass_trunk/dist.i686-
 pc-linux-gnu/etc/python/swig/raster.pyc /usr/local/src/grass_trunk/dist.
 i686-pc-linux-gnu/etc/python/swig/display.pyc
 gnu/etc/python/swig/stats.pyc /usr/local/src/grass_trunk/dist.i686-pc-
 linux-gnu/etc/python/swig/__init__.pyc
 /usr/bin/swig -I/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include
 -python -module utils -shadow utils.i
 test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
 gcc -fno-stack-protector -fPIC -I/usr/include/python2.5
 -I/usr/include/python2.5  -DPACKAGE=\""grasslibs"\"
 -I/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/include -o OBJ.i686-
 pc-linux-gnu/utils_wrap.o -c utils_wrap.c
 gcc -shared -o _utils.so -L/usr/local/src/grass_trunk/dist.i686-pc-linux-
 gnu/lib -Wl,--export-dynamic -Wl,-rpath-
 link,/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/lib
 -L/usr/local/src/grass_trunk/dist.i686-pc-linux-gnu/lib
 -L/usr/lib/python2.5/config -lpthread -ldl -lutil -lm -lpython2.5 OBJ.
 i686-pc-linux-gnu/utils_wrap.o
 /usr/bin/install -c  _utils.so /usr/local/src/grass_trunk/dist.i686-pc-
 linux-gnu/etc/python/swig/_utils.so
 -python -module date -shadow date.i
 pc-linux-gnu/date_wrap.o -c date_wrap.c
 gcc -shared -o _date.so -L/usr/local/src/grass_trunk/dist.i686-pc-linux-
 i686-pc-linux-gnu/date_wrap.o -lgrass_datetime
 /usr/bin/install -c  _date.so /usr/local/src/grass_trunk/dist.i686-pc-
 -python -module grass -shadow grass.i
 pc-linux-gnu/grass_wrap.o -c grass_wrap.c
 gcc -shared -o _grass.so -L/usr/local/src/grass_trunk/dist.i686-pc-linux-
 i686-pc-linux-gnu/grass_wrap.o -lgrass_gis -lgrass_datetime -lz
 /usr/bin/install -c  _grass.so /usr/local/src/grass_trunk/dist.i686-pc-
 -python -module math -shadow math.i
 pc-linux-gnu/math_wrap.o -c math_wrap.c
 gcc -shared -o _math.so -L/usr/local/src/grass_trunk/dist.i686-pc-linux-
 i686-pc-linux-gnu/math_wrap.o -lgrass_gmath -lgrass_gis -lgrass_datetime
 -lz
 /usr/bin/install -c  _math.so /usr/local/src/grass_trunk/dist.i686-pc-
 -python -module proj -shadow proj.i
 pc-linux-gnu/proj_wrap.o -c proj_wrap.c
 gcc -shared -o _proj.so -L/usr/local/src/grass_trunk/dist.i686-pc-linux-
 i686-pc-linux-gnu/proj_wrap.o -lgrass_gproj -lgrass_gis -lgrass_datetime
 -lz     -lproj  -L/usr/local/lib -lgdal
 /usr/bin/install -c  _proj.so /usr/local/src/grass_trunk/dist.i686-pc-
 -python -module imagery -shadow imagery.i
 pc-linux-gnu/imagery_wrap.o -c imagery_wrap.c
 gcc -shared -o _imagery.so -L/usr/local/src/grass_trunk/dist.i686-pc-
 linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-
 i686-pc-linux-gnu/imagery_wrap.o -lgrass_imagery -lgrass_gis
 /usr/bin/install -c  _imagery.so /usr/local/src/grass_trunk/dist.i686-pc-
 linux-gnu/etc/python/swig/_imagery.so
 -python -module vector -shadow vector.i
 pc-linux-gnu/vector_wrap.o -c vector_wrap.c
 gcc -shared -o _vector.so -L/usr/local/src/grass_trunk/dist.i686-pc-linux-
 i686-pc-linux-gnu/vector_wrap.o -lgrass_vect -lgrass_dbmibase -lgrass_gis
 -lgrass_datetime -lz      -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis
 -lgrass_datetime -lz      -lgrass_gis -lgrass_datetime -lz
 -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz
 -lgrass_rtree  -lgrass_gis -lgrass_datetime -lz     -lgrass_linkm
 -lgrass_rtree  -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz
 -lgrass_rtree  -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient
 -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz      -lgrass_gis
 -lgrass_datetime -lz      -lgrass_dbmibase -lgrass_gis -lgrass_datetime
 -lz       -L/usr/local/lib -lgdal
 /usr/bin/install -c  _vector.so /usr/local/src/grass_trunk/dist.i686-pc-
 -python -module raster -shadow raster.i
 pc-linux-gnu/raster_wrap.o -c raster_wrap.c
 gcc -shared -o _raster.so -L/usr/local/src/grass_trunk/dist.i686-pc-linux-
 i686-pc-linux-gnu/raster_wrap.o -lgrass_raster -lgrass_pngdriver
 -lgrass_driver -lgrass_gis -lgrass_datetime -lz        -lgrass_gis
 -lgrass_datetime -lz     -lpng  -lz  -lm  -lgrass_psdriver -lgrass_driver
 -lgrass_gis -lgrass_datetime -lz        -lgrass_gis -lgrass_datetime -lz
 /usr/bin/install -c  _raster.so /usr/local/src/grass_trunk/dist.i686-pc-
 -python -module display -shadow display.i
 pc-linux-gnu/display_wrap.o -c display_wrap.c
 gcc -shared -o _display.so -L/usr/local/src/grass_trunk/dist.i686-pc-
 i686-pc-linux-gnu/display_wrap.o -lgrass_display -lgrass_gis
 -lgrass_datetime -lz     -lgrass_raster -lgrass_pngdriver -lgrass_driver
 -lpng  -lz  -lm  -lgrass_psdriver -lgrass_driver -lgrass_gis
 /usr/bin/install -c  _display.so /usr/local/src/grass_trunk/dist.i686-pc-
 -python -module stats -shadow stats.i
 pc-linux-gnu/stats_wrap.o -c stats_wrap.c
 gcc -shared -o _stats.so -L/usr/local/src/grass_trunk/dist.i686-pc-linux-
 i686-pc-linux-gnu/stats_wrap.o -lgrass_stats -lgrass_gis -lgrass_datetime
 -lz
 /usr/bin/install -c  _stats.so /usr/local/src/grass_trunk/dist.i686-pc-
 linux-gnu/etc/python/swig/_stats.so
 /usr/bin/install -c  -m 644 utils.py /usr/local/src/grass_trunk/dist.i686-
 pc-linux-gnu/etc/python/swig/utils.py
 /usr/bin/install -c  -m 644 date.py /usr/local/src/grass_trunk/dist.i686-
 /usr/bin/install -c  -m 644 grass.py /usr/local/src/grass_trunk/dist.i686-
 /usr/bin/install -c  -m 644 math.py /usr/local/src/grass_trunk/dist.i686-
 /usr/bin/install -c  -m 644 proj.py /usr/local/src/grass_trunk/dist.i686-
 /usr/bin/install -c  -m 644 imagery.py /usr/local/src/grass_trunk/dist.
 /usr/bin/install -c  -m 644 vector.py /usr/local/src/grass_trunk/dist.
 i686-pc-linux-gnu/etc/python/swig/vector.py
 /usr/bin/install -c  -m 644 raster.py /usr/local/src/grass_trunk/dist.
 i686-pc-linux-gnu/etc/python/swig/raster.py
 /usr/bin/install -c  -m 644 display.py /usr/local/src/grass_trunk/dist.
 /usr/bin/install -c  -m 644 stats.py /usr/local/src/grass_trunk/dist.i686-
 gnu/etc/python/swig/__init__.py' is up to date.
 python -m py_compile /usr/local/src/grass_trunk/dist.i686-pc-linux-
 gnu/etc/python/swig/__init__.pyc' is up to date.
Ticket URL: <http://trac.osgeo.org/grass/ticket/434#comment:2>
