[GRASS-dev] Re: [GRASS GIS] #434: python swig bindings for 7.0 svn noyt working on ubuntu install
GRASS GIS trac at osgeo.org
Sat Jan 17 06:51:25 EST 2009
  Reporter:  mulligan  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  7.0.0
 Component:  Python    |     Version:  svn-trunk
Resolution:            |    Keywords:  python swig
  Platform:  Linux     |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:2 mulligan]:
 > Just updated to rev 35437 and still not getting the python_grass7.py
 files written
 That's correct. There isn't a python_grass7 module any more; instead there
 is a "swig" module with 10 separate sub-modules named:
 utils date grass math proj imagery vector raster display stats
 These can be imported individually with e.g. "import swig.grass", or you
 can import all of them with "import swig" (then use e.g.
 swig.grass.G_gisinit etc), or you can use e.g. "from swig.grass import *"
 to import all names from a module. You can do the latter for multiple
 modules, but AFAIK, there's no way to import names from all sub-modules of
 a module with a single command. OTOH, it wouldn't be hard to add an "all"
 sub-module which does "from <submodule> import *" for each submodule.
 Suggestions about the ideal structure for the Python interface are
 welcome. AFAICT, the previous structure was just the quickest way to get
 something working, rather than an explicit design choice.
 > here is the output of sudo make:
 That's a successful compilation.
Ticket URL: <http://trac.osgeo.org/grass/ticket/434#comment:3>
