[GRASS-dev] GRASS won't compile - can't 'find' gdal
William Kyngesburye
woklist at kyngchaos.com
Mon Jan 19 10:11:59 EST 2009
On Jan 19, 2009, at 3:03 AM, Andreas Hörsken wrote:
> gcc -o conftest -g -O2 -I/Library/Frameworks/GDAL.framework/
> Versions/1.5/Headers conftest.c -L/Library/Frameworks/
> GDAL.framework/Versions/1.5/unix/lib -lgdal 1>&5
> /usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld: warning can't open
> dynamic library: @loader_path/Libraries/libogdi.dylib referenced
> from: /Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib/
> libgdal.dylib (checking for undefined symbols may be affected) (No
> such file or directory, errno = 2)
> So there are problems with loading other libraries (not the gdal-
> library).
> Has someone an idea why this goes wrong? I installed all frameworks
> needed from http://www.kyngchaos.com/software:grass/
Which exact version of the GDAL framework do you have installed?
Does "gdalinfo --formats" work in a Terminal?
Try these exports before running configure:
export CFLAGS=-Os
export CXXFLAGS=-Os
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
