[GRASS-dev] GRASS won't compile - can't 'find' gdal
William Kyngesburye
woklist at kyngchaos.com
Mon Jan 19 11:15:27 EST 2009
On Jan 19, 2009, at 9:49 AM, Andreas Hörsken wrote:
> Hi,
> thanks for your help. The hint about the ogdi library solved the
> problem for me.
> It seems that the gdal-framework provided at www.kyngchaos.com needs
> these libraries but I hadn't them installed.
They are inside the GDAL framework bundle. That "@loader_path" is a
relative reference to the "loading" binary, which should be GDAL. For
some reason this isn't working from configure.
> First I tried to compile the ogdi library with these instructions
> for macosx:
> (http://grass.itc.it/platforms/macgrass/ogdi.php) and (http://www.kyngchaos.com/macosx:build:ogdi
> But that didn't work - there were so much unresolved includes that I
> gave it up to compile ogdi.
Those instructions are a bit out of date, though should be good for
OGDI 3.1.6 (current stable). But I think much of the hackery isn't
needed in OGDI 3.2 beta.
> What did the trick for me was compiling gdal by hand with the '--
> without-ogdi' configure-option (see http://www.kyngchaos.com/macosx:build:gdal
> ) as macosx framework.
Unless you leave the other bundled stuff there from my packaged GDAL,
you'll probably lose the GRASS and Postgres formats.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
