[GRASS-dev] GRASS won't compile - can't 'find' gdal
Andreas Hörsken
andreas.hoersken at uni-dortmund.de
Mon Jan 19 10:49:42 EST 2009
thanks for your help. The hint about the ogdi library solved the
problem for me.
It seems that the gdal-framework provided at www.kyngchaos.com needs
these libraries but I hadn't them installed. First I tried to compile
the ogdi library with these instructions for macosx:
(http://grass.itc.it/platforms/macgrass/ogdi.php) and (http://
www.kyngchaos.com/macosx:build:ogdi)
But that didn't work - there were so much unresolved includes that I
gave it up to compile ogdi.
What did the trick for me was compiling gdal by hand with the '--
without-ogdi' configure-option (see http://www.kyngchaos.com/
macosx:build:gdal ) as macosx framework.
Thanks again,
Andreas.
Am 19.01.2009 um 10:44 schrieb Markus Metz:
> Andreas Hörsken wrote:
>> I tried to compile grass on Macosx 10.4.11 (Tiger) today an got
>> the same error message when running configure:
>> checking for gdal-config... /Library/Frameworks/GDAL.framework/
>> Programs/gdal-config
>> configure: error: *** Unable to locate GDAL library.
>> The same happens with all versions of grass (i.e. grass-6.2.3,
>> grass-6.3.0, grass-6.4.0RC2, grass-6.4.svn, grass-7.0.svn). I
>> attached the build script and the config.log to this mail, but the
>> important part from the config.log should be the following:
>> gcc -o conftest -g -O2 -I/Library/Frameworks/GDAL.framework/
>> Versions/1.5/Headers conftest.c -L/Library/Frameworks/
>> GDAL.framework/Versions/1.5/unix/lib -lgdal 1>&5
>> /usr/libexec/gcc/i686-apple-darwin8/4.0.1/ld: warning can't open
>> dynamic library: @loader_path/Libraries/libogdi.dylib referenced
>> from:
> The path to the ogdi library is not known to the system and must be
> included. gdalinfo --formats should also not work (or any other
> gdal utilities). I have the same problem under Linux if I don't
> include the path to the custom compiled ogdi library in the system-
> wide library path. Under Linux I create a new file named ogdi.conf
> under /etc/ld.so.conf.d/ with the path to the ogdi library in it,
> then it works, no idea about how to do it on a Mac.
> I hope this points to the right direction.
> Markus M
>> /Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib/
>> libgdal.dylib (checking for undefined symbols may be affected) (No
>> such file or directory, errno = 2)
>> So there are problems with loading other libraries (not the gdal-
>> library).
>> Has someone an idea why this goes wrong? I installed all
>> frameworks needed from http://www.kyngchaos.com/software:grass/
>> Thanks,
>> Andreas.
>> Am 06.07.2008 um 21:51 schrieb Michael Barton:
>>> I just tried to compile GRASS yesterday to catch up. It won't get
>>> past configure, giving a gdal not found error.
>>> I'm using a Mac with OS X 10.5 I'm using the same configuration
>>> string that worked a couple weeks back. I updated from source
>>> yesterday (GRASS 6.4 and 7 give the same results). To be on the
>>> safe side, after getting these errors, I updated my frameworks
>>> (including the gdal framework), from William Kyngesbury's site.
>>> Same result.
>>> William mentioned that other people have had similar issues. So,
>>> I've pasted in my configure string and configure output below and
>>> attached the config.log file. If anyone has suggestions I'll try
>>> them out.
>>> Thanks
>>> Michael
>>> ____________________
>>> C. Michael Barton, Professor of Anthropology
>>> Director of Graduate Studies
>>> School of Human Evolution & Social Change
>>> Center for Social Dynamics & Complexity
>>> Arizona State University
>>> Phone: 480-965-6262
>>> Fax: 480-965-7671
>>> www: <www.public.asu.edu/~cmbarton <http://www.public.asu.edu/%
>>> 7Ecmbarton>>
>>> <config.log>
>>> =========== configure string and output ============
>>> Last login: Sat Jul 5 18:26:18 on ttys000
>>> cmb-MBP-2:~ cmbarton$ cd /Users/cmbarton/grass_dev/grass6_src cmb-
>>> MBP-2:grass6_src cmbarton$ export NAD2BIN=/Library/Frameworks/
>>> PROJ.framework/Programs/nad2bin
>>> cmb-MBP-2:grass6_src cmbarton$ ./configure --with-freetype --with-
>>> freetype-includes="/Library/Frameworks/FreeType.framework/unix/
>>> include/freetype2 /Library/Frameworks/FreeType.framework/unix/
>>> include" --with-freetype-libs=/Library/Frameworks/
>>> FreeType.framework/unix/lib --with-gdal=/Library/Frameworks/
>>> GDAL.framework/Programs/gdal-config --with-proj --with-proj-
>>> includes=/Library/Frameworks/PROJ.framework/unix/include --with-
>>> proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-
>>> share=/Library/Frameworks/PROJ.framework/Resources/proj --with-
>>> jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/
>>> include --with-jpeg-libs=/Library/Frameworks/
>>> UnixImageIO.framework/unix/lib --with-png-includes=/Library/
>>> Frameworks/UnixImageIO.framework/unix/include --with-png-libs=/
>>> Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-
>>> includes=/Library/Frameworks/UnixImageIO.framework/unix/include --
>>> with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
>>> --without-postgres --without-mysql --with-odbc --with-sqlite --
>>> with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --
>>> with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/
>>> include --with-fftw-includes=/Library/Frameworks/FFTW3.framework/
>>> unix/include --with-fftw-libs=/Library/Frameworks/FFTW3.framework/
>>> unix/lib --with-cxx --with-tcltk-includes=/usr/local/tcltk/
>>> include --with-tcltk-libs=/usr/local/tcltk/lib --with-x --without-
>>> motif --without-glw --with-opengl=x11 --with-opengl-libs=/usr/
>>> X11R6/lib --without-readline --prefix=/Applications/GRASS --
>>> enable-macosx-app --with-python --with-wxwidgets=/usr/local/lib/
>>> wxPython-unicode-2.8.7.1/bin/wx-config
>>> checking host system type... i386-apple-darwin9.4.0
>>> checking for gcc... gcc
>>> checking whether the C compiler (gcc ) works... yes
>>> checking whether the C compiler (gcc ) is a cross-compiler... no
>>> checking whether we are using GNU C... yes
>>> checking whether gcc accepts -g... yes
>>> checking for Cygwin environment... no
>>> checking for mingw32 environment... no
>>> checking for executable suffix... no
>>> checking for full floating-point support... yes
>>> checking for pwd... /bin/pwd
>>> checking for source directory... /Users/cmbarton/grass_dev/
>>> grass6_src
>>> checking for build directory... /Users/cmbarton/grass_dev/grass6_src
>>> checking for MacOSX App... yes
>>> checking how to build libraries... shared
>>> checking for ranlib... ranlib
>>> checking how to run the C preprocessor... gcc -E
>>> checking if 64bit support is requested... no
>>> checking if 64bit Sparc VIS support is requested... no
>>> checking system version (for dynamic loading)... Darwin-9.4.0
>>> checking for dlopen in -ldl... yes
>>> checking for ar... ar
>>> checking for additional include dirs... checking for additional
>>> library dirs... checking for a BSD compatible install... /usr/bin/
>>> install -c
>>> checking for flex... flex
>>> checking for yywrap in -lfl... yes
>>> checking for bison... bison -y
>>> checking for env... env
>>> checking for perl... /usr/bin/perl
>>> checking for ANSI C header files... yes
>>> checking for limits.h... yes
>>> checking for termio.h... no
>>> checking for termios.h... yes
>>> checking for unistd.h... yes
>>> checking for values.h... no
>>> checking for f2c.h... no
>>> checking for g2c.h... no
>>> checking for sys/ioctl.h... yes
>>> checking for sys/mtio.h... yes
>>> checking for sys/resource.h... yes
>>> checking for sys/time.h... yes
>>> checking for sys/timeb.h... yes
>>> checking for sys/types.h... yes
>>> checking for sys/utsname.h... yes
>>> checking for libintl.h... no
>>> checking for iconv.h... yes
>>> checking for langinfo.h... yes
>>> checking whether time.h and sys/time.h may both be included... yes
>>> checking for off_t... yes
>>> checking for uid_t in sys/types.h... yes
>>> checking return type of signal handlers... void
>>> checking for ftime... yes
>>> checking for gethostname... yes
>>> checking for gettimeofday... yes
>>> checking for lseek... yes
>>> checking for nice... yes
>>> checking for time... yes
>>> checking for uname... yes
>>> checking for seteuid... yes
>>> checking for setpriority... yes
>>> checking for setreuid... yes
>>> checking for setruid... yes
>>> checking for drand48... yes
>>> checking for putenv... yes
>>> checking for setenv... yes
>>> checking for nanosleep... yes
>>> checking whether setpgrp takes no argument... yes
>>> checking for long long int... yes
>>> checking for W11... no
>>> checking for X... libraries /usr/X11/lib, headers /usr/X11/include
>>> checking for dnet_ntoa in -ldnet... no
>>> checking for dnet_ntoa in -ldnet_stub... no
>>> checking for gethostbyname... yes
>>> checking for connect... yes
>>> checking for remove... yes
>>> checking for shmat... yes
>>> checking for IceConnectionNumber in -lICE... yes
>>> checking whether to use Curses... yes
>>> checking for curses.h... yes
>>> checking curses.h WINDOW structure component... _maxy
>>> checking for initscr in -lncurses... yes
>>> checking for keypad in -lncurses... yes
>>> checking for gtty in -lcompat... no
>>> checking for gtty in -lbsd-compat... no
>>> checking for gtty in -lbsd... no
>>> checking for library containing cuserid... no
>>> checking for xdrmem_create... yes
>>> checking for asprintf... yes
>>> checking for atan... yes
>>> checking for dlsym... yes
>>> checking for iconv... no
>>> checking for iconv in -liconv... yes
>>> checking for socket... yes
>>> checking for location of zlib includes... checking for zlib.h... yes
>>> checking for location of zlib library... checking for deflate in -
>>> lz... yes
>>> checking for location of External PROJ.4 includes... /Library/
>>> checking for proj_api.h... yes
>>> checking External PROJ.4 version... 460
>>> checking for location of External PROJ.4 library... /Library/
>>> checking for pj_get_def in -lproj... yes
>>> checking for location of External PROJ.4 data files... /Library/
>>> checking for /Library/Frameworks/PROJ.framework/Resources/proj/
>>> epsg... yes
>>> checking for nad2bin... /Library/Frameworks/PROJ.framework/
>>> Programs/nad2bin
>>> checking whether to use Readline... no
>>> checking whether to use JPEG... yes
>>> checking for location of JPEG includes... /Library/Frameworks/
>>> checking for jpeglib.h... yes
>>> checking for location of JPEG library... /Library/Frameworks/
>>> checking for jpeg_start_compress in -ljpeg... yes
>>> checking whether to use GDAL... yes
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
