[GRASS-dev] lib/form/ and Tcl 8.6 compile problem
Maris Nartiss
maris.gis at gmail.com
Tue Jan 20 05:20:48 EST 2009
Hello,
there was similar issue reported on Mac. It comes from tcl.h where
they recommend not to use result:
463 typedef struct Tcl_Interp {
464 /* TIP #330: Strongly discourage extensions from using the
string result. */
465 #ifdef USE_INTERP_RESULT
I'm not a make process guru to propose solution.
Maris.
2009/1/20, Markus Neteler <neteler at osgeo.org>:
> hi,
> I tried to compile GRASS on Mandriva Cooker which comes (currently)
> with
> rpm -qa | grep tcl
> tcl-8.6-0.b1.1mdv2009.1
> libtcl-devel-8.6-0.b1.1mdv2009.1
> libtcl8.6-8.6-0.b1.1mdv2009.1
> I get this problem with 6.4:
> cd lib/form/
> make
> gcc -I/home/guest/rpm/BUILD/grass-6.4/dist.i686-pc-linux-gnu/include
> -g -O2 -fPIC -DPACKAGE=\""grasslibs"\"
> -I/home/guest/rpm/BUILD/grass-6.4/dist.i686-pc-linux-gnu/include -o
> OBJ.i686-pc-linux-gnu/form.o -c form.c
> form.c: In function 'submit':
> form.c:195: error: 'Tcl_Interp' has no member named 'result'
> make: *** [OBJ.i686-pc-linux-gnu/form.o] Error 1
> The code looks like this:
> 190 else {
> 191 memset(buf, '\0', strlen(buf));
> 192 ret = Tcl_UtfToExternal(interp,
> 193
> Tcl_GetEncoding(interp,
> 194
> G__getenv
> 195
> ("GRASS_DB_ENCODING")),
> 196 Columns[i].value,
> 197
> strlen(Columns[i].value), 0, NULL,
> 198 buf, 2000, NULL, NULL,
> NULL);
> Any idea how to solve this?
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
