[GRASS-dev] lib/form/ and Tcl 8.6 compile problem
Markus Neteler
neteler at osgeo.org
Tue Jan 20 18:34:42 EST 2009
On Tue, Jan 20, 2009 at 11:20 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
> Hello,
> there was similar issue reported on Mac. It comes from tcl.h where
> they recommend not to use result:
> 463 typedef struct Tcl_Interp {
> 464 /* TIP #330: Strongly discourage extensions from using the
> string result. */
> 465 #ifdef USE_INTERP_RESULT
Good hint!
They propose to use Tcl_GetObjResult():
http://wiki.tcl.tk/21120
Is the following patch nonsense?
Index: form.c
--- form.c (revision 35372)
+++ form.c (working copy)
@@ -192,7 +192,7 @@
TCL_ERROR) {
G_warning
("Could not set Tcl system encoding to '%s' (%s)",
- Columns[i].value, interp->result);
+ Columns[i].value, (char *) Tcl_GetObjResult(interp));
continue;
Wild guessing :)
Markus
