[GRASS-dev] lib/form/ and Tcl 8.6 compile problem
Maris Nartiss
maris.gis at gmail.com
Wed Jan 21 11:58:16 EST 2009
Yes, it is :)
In short - no one has eliminated old tcl/tk versions out there. Any
patch needs to work with old and new approach too. Also forms isn't
the only place where interp result is used (lazy to grep)
Maris.
2009/1/21 Markus Neteler <neteler at osgeo.org>:
> On Tue, Jan 20, 2009 at 11:20 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
>> Hello,
>> there was similar issue reported on Mac. It comes from tcl.h where
>> they recommend not to use result:
>> 463 typedef struct Tcl_Interp {
>> 464 /* TIP #330: Strongly discourage extensions from using the
>> string result. */
>> 465 #ifdef USE_INTERP_RESULT
> Good hint!
> They propose to use Tcl_GetObjResult():
> http://wiki.tcl.tk/21120
> Is the following patch nonsense?
> Index: form.c
> --- form.c (revision 35372)
> +++ form.c (working copy)
> @@ -192,7 +192,7 @@
> TCL_ERROR) {
> G_warning
> ("Could not set Tcl system encoding to '%s' (%s)",
> - Columns[i].value, interp->result);
> + Columns[i].value, (char *) Tcl_GetObjResult(interp));
> continue;
> Wild guessing :)
> Markus
