[GRASS-dev] Re: [GRASS-user] interactive multiple selection
Moritz Lennert
mlennert at club.worldonline.be
Sat Jan 24 05:25:05 EST 2009
On 23/01/09 11:05, Benjamin Ducke wrote:
> I guess it allows per-map WHERE clauses for those modules that take
> multiple input maps (such as v.patch). The global "where=" option
> does not and assumes that all input maps have the same attribute
> table structure and data ranges?
I think this actually raises a question discussed two years ago [1],
i.e. whether we would actually think of a way more SQL-centric way of
dealing with maps.
At the time, I implemented a proof-of-concept version of d.vect.chart
which allowed displaying the results of an arbitrary SQL-query, as long
as these results contained cat values linked to the chosen map. [2]
The discussion died down after that, but maybe grass7 would be a good
opportunity to wake it up.
Moritz
[1]http://lists.osgeo.org/pipermail/grass-user/2006-September/036414.html
[2]http://lists.osgeo.org/pipermail/grass-dev/2006-October/026625.html
> Ben
> Moritz Lennert wrote:
>> On 22/01/09 21:50, Hamish wrote:
>>> slightly-related, but before I forget, I had an idea about the "adding
>>> where= SQL queries to all vector modules in gr7" wish. hijack the parser
>>> with a semi-colon.
>>> for example:
>>> v.module input="roads; WHERE surface IS 'gravel'"
>> In what ways do you feel this is superior to input= where= ?
>> Moritz
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
