[GRASS-dev] Re: [GRASS GIS] #668: export and share region settings
trac at osgeo.org
Wed Jul 1 05:43:54 EDT 2009
Reporter: timmie | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: g.region
Platform: Linux | Cpu: x86-32
Comment (by martinl):
Replying to [comment:2 timmie]:
> I sometime have different locations with the same projection and same
area.
> It would be nice to share the region information between them.
> Just like saving the layer settings can be saved, too.
Save workspace with no defined map layer? Workspace has at least
information about display region. Then to set computation region for
display and fix resolution. Probably too much tricky. Should workspace
store also computation region and change current computation region when
loading wokrspace file?
Ticket URL: <https://trac.osgeo.org/grass/ticket/668#comment:3>
