[GRASS-dev] Re: [GRASS GIS] #667: please allow to export projection information in more formats
GRASS GIS trac at osgeo.org
Wed Jul 1 07:40:48 EDT 2009
  Reporter:  timmie       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  normal       |   Milestone:  6.5.0
 Component:  default      |     Version:  svn-develbranch6
Resolution:               |    Keywords:  g.proj
  Platform:  Linux        |         Cpu:  x86-32
Comment (by hamish):
 > > Also, what does GMT format look like?
 > It's like:
 >  -JB-100/35/33/45/6i
 I'm not sure what the `-JB` and `/6i` are for
        -R     xmin, xmax, ymin, and ymax specify the Region of interest.
               For  geographic  regions, these limits correspond to west,
               east, south, and north and you may specify them in decimal
               degrees  or in [+-]dd:mm[:ss.xxx][W|E|S|N] format.  Append
               r if lower left and upper right map coordinates are  given
               instead  of  wesn.   The  two shorthands -Rg -Rd stand for
               global domain (0/360 or  -180/+180  in  longitude  respec-
               tively,  with  -90/+90  in  latitude).
 they use the same D:M:S format as us, should be pretty easy to add a new
 -t flag for that... standby.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/667#comment:4>
