[GRASS-dev] Submitting module to addons - r.sundenoise - mentor
required
Glynn Clements
glynn at gclements.plus.com
Fri Jul 3 18:47:14 EDT 2009
Hamish wrote:
> So (IIU this C*), why should the removal of shell script support not be
> reverted? What does it cost us to keep shell script support?**
> [*] & I suspect I may not.
The "support" which has been removed is limited to the build system.
If you include Script.make, the directory must contain $(PGM).py or
you get an error.
People are free to script GRASS commands in whatever language they
choose, but shell scripts don't belong in the GRASS 7 repository, so
there's no need for the build system to provide any support for them.
If something doesn't work unless you install /bin/sh and a dozen other
Unix utilities, that's a critical bug. Ditto for anything which
doesn't work if $GISBASE or GISDBASE contain spaces.
