[GRASS-dev] [GRASS GIS] #673: v.db.addtable uses wrong postgres schema
GRASS GIS trac at osgeo.org
Sat Jul 4 09:04:02 EDT 2009
 Reporter:  fengel                |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                |      Status:  new
 Priority:  normal                |   Milestone:  6.4.0
Component:  Database              |     Version:  6.4.0 RCs
 Keywords:  v.db.addtable schema  |    Platform:  Linux
      Cpu:  x86-32                |
 Creating a table in a postgresql database:
 After dissolving with v.extract -d using the new= parameter I tried to
 use v.db.addtable to create a table for my dissolved map.
 v.db.addtable creates a table, but doesn't put it in the right
 database schema. It is created in the schema "public" and not in the
 current schema, although db.connect -p verifys that
 all connection parameters are correctly set.
Ticket URL: <http://trac.osgeo.org/grass/ticket/673>
