[GRASS-dev] Re: [GRASS GIS] #675: r.proj's "use different location"
error while working in different dbases
trac at osgeo.org
Sun Jul 5 10:18:35 EDT 2009
#675: r.proj's "use different location" error while working in different dbases
Reporter: nikos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: unspecified
Resolution: | Keywords: r.proj, dbase, location, indbase->answer, inlocation->answer
Platform: Unspecified | Cpu: Unspecified
Comment (by nikos):
Replying to [comment:1 hamish]:
> the bug appears as follows. r.proj(.seg) has the following check:
> > if (strcmp(inlocation->answer, G_location()) == 0)
> > G_fatal_error(_("You have to use a different location for
input than the current"));
> which fails if the location name is the same in both gisdbases. does it
work if you leave the location= option blank? (default for mapsets is to
assume the same, maybe location name too)
No, it does not work and the error message (correctly I suppose) is:
ERROR: G_getenv(): Variable LOCATION_NAME not set
Nikos
Ticket URL: <http://trac.osgeo.org/grass/ticket/675#comment:3>
