[GRASS-dev] Re: [GRASS GIS] #676: r.watershed: different output map
options do not allow for fully qualified map names
trac at osgeo.org
Tue Jul 7 04:14:55 EDT 2009
#676: r.watershed: different output map options do not allow for fully qualified
map names
Reporter: mlennert | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.watershed
Platform: Linux | Cpu: Unspecified
Comment (by mlennert):
Replying to [comment:3 hamish]:
> Replying to [comment:2 mlennert]:
> > Ok, but then the wxGUI should not automatically add @mapset
> > when you chose an existing file for output. So, maybe this
> > should be reclassified as a wxGUI bug.
> Output raster options with
> opt->gisprompt = "new,cell,raster";
> should not be presenting the user with a list of existing maps to choose
from in the first place.
Well, it _is_ convienient in the GUI to be able to chose an existing map
if you want to replace it...
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/676#comment:4>
