[GRASS-dev] Re: [GRASS GIS] #676: r.watershed: different output map options do not allow for fully qualified map names
GRASS GIS trac at osgeo.org
Tue Jul 7 05:04:20 EDT 2009
map names
  Reporter:  mlennert  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  normal    |   Milestone:  6.4.0
 Component:  Raster    |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  r.watershed
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by mmetz):
 Replying to [comment:4 mlennert]:
 > Replying to [comment:3 hamish]:
 > > Replying to [comment:2 mlennert]:
 > > > Ok, but then the wxGUI should not automatically add @mapset
 > > > when you chose an existing file for output. So, maybe this
 > > > should be reclassified as a wxGUI bug.
 > > Output raster options with
 > >  opt->gisprompt = "new,cell,raster";
 > > should not be presenting the user with a list of existing maps to
 choose from in the first place.
 > Well, it _is_ convienient in the GUI to be able to chose an existing map
 if you want to replace it...
 I agree, but should it then be the responsibility of the module to strip
 any @mapset parts or the responsibility of the parser? It seems that this
 is a more general question that also applies to other raster as well as
 vector modules.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/676#comment:5>
