[GRASS-dev] Re: [GRASS GIS] #676: r.watershed: different output map
options do not allow for fully qualified map names
trac at osgeo.org
Tue Jul 7 10:57:55 EDT 2009
#676: r.watershed: different output map options do not allow for fully qualified
map names
Reporter: mlennert | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.watershed
Platform: Linux | Cpu: Unspecified
Comment (by mlennert):
Replying to [comment:7 glynn]:
> Replying to [comment:6 mlennert]:
> > IIUC, the problem actually comes from the use of G_legal_filename() in
these modules (r.reclass is another of them). So the question is: should
modules check for legality of given file names ?
> File names or map names?
I meant map names.
> > And if yes, should they use G_legal_filename().
> Modules shouldn't normally use this function. It's meant for use by low-
level library functions.
Can we just delete the check then ? In any case there will be an error at
creation if the map name is illegal, or ?
> If modules are passing map names to it, the modules should be fixed.
Grepping for G_legal_filename in grass6 (trunk and 64 releasebranch)
throws up lots of occurences which at first sight seem to pass map names.
None left in grass7, so I guess you have already cleaned up ?
Should this also be done in 6.* ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/676#comment:8>
