[GRASS-dev] Re: [GRASS GIS] #676: r.watershed: different output map
options do not allow for fully qualified map names
trac at osgeo.org
Tue Jul 7 12:30:39 EDT 2009
#676: r.watershed: different output map options do not allow for fully qualified
map names
Reporter: mlennert | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.watershed
Platform: Linux | Cpu: Unspecified
Comment (by mmetz):
Replying to [comment:1 hamish]:
> you may only write to the current mapset. therefore @othermapset is not
needed for output maps.
> if it is given, and the value is the current mapset, then perhaps it
should be quietly ignored. hopefully it could be done at the library
level. if it can't be handled at the lib level I'd be inclined to ignore
it rather than add clutter to all raster modules.
FWIW, Vect_open_new() does that job for vectors, it removes any @mapset
from fully qualified names. Should Rast_open_new() behave similarly? Then
it would be handled on library level, raster modules need not be touched.
And opening new raster maps and new vector maps would be more consistent.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/676#comment:10>
