[GRASS-dev] Re: [GRASS GIS] #676: r.watershed: different output map options do not allow for fully qualified map names
GRASS GIS trac at osgeo.org
Wed Jul 8 11:17:46 EDT 2009
map names
  Reporter:  mlennert  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  normal    |   Milestone:  6.4.0
 Component:  Raster    |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  r.watershed
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:8 mlennert]:
 > > > And if yes, should they use G_legal_filename().
 > > Modules shouldn't normally use this function. It's meant for use by
 low-level library functions.
 > Can we just delete the check then ? In any case there will be an error
 at creation if the map name is illegal, or ?
 The library functions which create maps, support files, etc should be
 calling G_legal_filename() as needed.
 > > If modules are passing map names to it, the modules should be fixed.
 > Grepping for G_legal_filename in grass6 (trunk and 64 releasebranch)
 throws up lots of occurences which at first sight seem to pass map names.
 None left in grass7, so I guess you have already cleaned up ?
 > Should this also be done in 6.* ?
 Ideally, yes.
Ticket URL: <https://trac.osgeo.org/grass/ticket/676#comment:11>
