[GRASS-dev] Re: [GRASS GIS] #671: wxgui: v.distance to_column option inaccessible
GRASS GIS trac at osgeo.org
Wed Jul 8 15:56:33 EDT 2009
  Reporter:  mlennert  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  v.distance to_column
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by martinl):
 The patch for trunk attached. If {{{guidependency}}} is not defined, the
 current approach would be applied, so e.g. for layer/columns - if 'layer'
 value is changed, all G_OPT_DB_COLUMNS will be updated. In the case that
 'layer' option has defined {{{guidependency}}} attribute, only mentioned
 options will be updated.
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/671#comment:9>
