[GRASS-dev] Re: [GRASS GIS] #671: wxgui: v.distance to_column option inaccessible
GRASS GIS trac at osgeo.org
Thu Jul 9 04:39:23 EDT 2009
  Reporter:  mlennert  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  6.4.0 RCs
Resolution:            |    Keywords:  v.distance to_column
  Platform:  Linux     |         Cpu:  Unspecified
Comment (by martinl):
 Replying to [comment:9 martinl]:
 > The patch for trunk attached. If {{{guidependency}}} is not defined, the
 current approach would be applied, so e.g. for layer/columns - if 'layer'
 value is changed, all G_OPT_DB_COLUMNS will be updated. In the case that
 'layer' option has defined {{{guidependency}}} attribute, only mentioned
 options will be updated.
 Any objections to commit the changes to trunk? BTW, we could simplify
 {{{gisprompt}}} attribute. Currently
 age,element,prompt
 Probably 'element' could discarded?
Ticket URL: <http://trac.osgeo.org/grass/ticket/671#comment:10>
