[GRASS-dev] v.edit map
Moritz Lennert mlennert at club.worldonline.be
Thu Jul 9 10:51:25 EDT 2009
On 09/07/09 11:30, Martin Landa wrote:
> Hi,
> should be 'map' in v.edit (for GRASS7) replaced by 'input/output'?
> When options are specified incorrectly or the module crashes, vector
> is not backuped, data are lost. The input/output paramaters would be
> probably better for this module.
Not too sure about this: this would mean that you create an intermediate
map for every small edit. Why not create a flag for allowing the
creation of a backup copy of the original map (which could be the
default, so flag would then disable creation of backup map) ? Thus you
get the security of being able to find the last version of the map
before v.edit, without populating your mapset with a large number of
intermediate maps.
Moritz
