[GRASS-dev] v.edit map
    Martin Landa
    landa.martin at gmail.com
    Thu Jul  9 10:56:28 EDT 2009
2009/7/9 Moritz Lennert <mlennert at club.worldonline.be>:
>> should be 'map' in v.edit (for GRASS7) replaced by 'input/output'?
>> When options are specified incorrectly or the module crashes, vector
>> is not backuped, data are lost. The input/output paramaters would be
>> probably better for this module.
> Not too sure about this: this would mean that you create an intermediate map
> for every small edit. Why not create a flag for allowing the creation of a
> backup copy of the original map (which could be the default, so flag would
> then disable creation of backup map) ? Thus you get the security of being
> able to find the last version of the map before v.edit, without populating
> your mapset with a large number of intermediate maps.
or to make 'output' parameter optional. I.e. if 'output' is not given
then the vector map is modified directly otherwise saved as 'output'.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
