[GRASS-dev] vector libs: file based spatial index
Martin Landa landa.martin at gmail.com
Thu Jul 9 14:59:29 EDT 2009
Hi Markus,
2009/7/7 Markus Metz <markus.metz.giswork at googlemail.com>:
> For the time being, the only reasonable way to deal with these massive
> datasets is to *not* build topology. It's not not only the spatial index
> that is getting out of hand, also topology itself and the category
> index. The grass vector libs must be told that there is nothing special
> about point datasets (to cite Hamish) which means rewriting major parts
> of the vector libs, and that takes time.
BTW, are you planning to commit your changes in sidx to trunk?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
