[GRASS-dev] Re: [GRASS GIS] #35: Verify and uncomment Swiss datum
parameters
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Sun Jul 12 16:03:01 EDT 2009
maybe this can help (CH1903 to WGS84):
http://www.swisstopo.admin.ch/internet/swisstopo/en/home/products/software/products/skripts.html
GRASS GIS wrote:
> #35: Verify and uncomment Swiss datum parameters
> Reporter: neteler | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: closed
> Priority: major | Milestone: 6.4.0
> Component: Projections/Datums | Version: unspecified
> Resolution: fixed | Keywords: CH1903, Swiss
> Platform: Unspecified | Cpu: Unspecified
> Comment (by pkelly):
> My understanding: ETRS89 is fixed to the European/Eurasian plate. It was
> the same as WGS84 in 1989 and since then has been drifting by a centimetre
> or two per year. But the ellipsoid is the same (well, given the
> GRS80/WGS84 difference which is miniscule). Presumably it's quite easy to
> compensate for the drift between ETRS89 and WGS84 when interpreting GPS
> co-ordinates (do some GPS receivers do this? I have no idea), and then
> after that it is simple to apply a localised country datum transformation
> grid or parameters, which don't change over time.
> The interesting thing about CH1903+ is that it is only compatible with
> ETRS89 in the sense that a simple rotation brings it into alignment
> (3-parameter transform) and there is negligible distortion. But to convert
> from CH1903 to ETRS89 you first need to apply the gridshift transform to
> remove the localised surveying distortions and get to CH1903+, and then
> apply the rotation separately. However the structure of PROJ.4 only allows
> for the concept of a gridshift file converting to WGS84.
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Dr. Eng. Massimiliano Cannata
Responsabile Area Geomatica
Istituto Scienze della Terra
Scuola Universitaria Professionale della Svizzera Italiana
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
