[GRASS-dev] GRASS7 rasterlib broken?
Markus Metz markus.metz.giswork at googlemail.com
Wed Jul 15 16:55:00 EDT 2009
Glynn Clements wrote:
> Markus Metz wrote:
>>> Splitting libgis into libgis and libraster means splitting G_gisinit()
>>> into G_gisinit() and Rast_init(). Obviously, if you split the function
>>> in two, any calls to the function also need to be split.
>>> I'll look into doing one-shot initialisation within the raster
>>> library.
>> It's a long stretch but what Rast_init() does may be in principle
>> similar to what does dig_init_portable() in the vector libs.
>> Initialisating of the raster libs in library instead of in module may
>> not be much of a time penalty since you're using static int initialized.
>> BTW, can a system with a byte order different from the byte order of the
>> original system read grass raster maps created on the original system?
> The core raster and vector file formats are portable. There are a few
> instances where auxiliary files under cell_misc use platform-specific
> formats, e.g. the FFT data generated by i.fft and read by i.fft (this
> doesn't apply to 7.0, where the FFT data is stored as raster maps
> rather than auxiliary files).
Thanks for the info. I admit I am too lazy to read the relevant code
(because I don't know where it is).
Getting more technical: does it make sense to port rasterIO ideas to
vectorIO or vice versa?
Markus M
