[GRASS-dev] SWIG-Python lacking from install sequence in main Makefile
Sun Jul 19 23:53:59 EDT 2009
Hamish wrote:
> so (IIUC) swig 1.3.29 requires python >= 2.5 ?
FWIW, the wrappers generated by SWIG 1.3.36 have:
	/* Py_ssize_t for old Pythons */
	/* This code is as recommended by: */
	/* http://www.python.org/dev/peps/pep-0353/#conversion-guidelines */
	#if PY_VERSION_HEX < 0x02050000 && !defined(PY_SSIZE_T_MIN)
	typedef int Py_ssize_t;
	# define PY_SSIZE_T_MAX INT_MAX
	# define PY_SSIZE_T_MIN INT_MIN
	#endif
IOW, you should just need a newer version of SWIG.
