[GRASS-dev] SWIG-Python lacking from install sequence in main
Makefile
Hamish
hamish_b at yahoo.com
Mon Jul 20 01:27:19 EDT 2009
Hamish:
> > so (IIUC) swig 1.3.29 requires python >= 2.5 ?
Glynn:
> FWIW, the wrappers generated by SWIG 1.3.36 have:
> IOW, you should just need a newer version of SWIG.
aka ask users to upgrade their OS in order to install a user app. :-/
If this can not be worked around, anyone know what the minimum required
swig version is?
Then we can at least document --with-python in REQUIREMENTS.html
Would it be like swig >= 1.3.x OR python >= 2.5 ?
it passes all the --with-python checks, could ./configure be improved
to bail if actual requirements are not met?
checking whether to use Python... yes
checking for python-config... /usr/bin/python2.4-config
checking for Python.h... yes
checking for swig... /usr/bin/swig
thanks,
Hamish
