[GRASS-dev] 7.svn fails to build from source
Michael Barton
Michael.Barton at asu.edu
Tue Jul 21 11:22:16 EDT 2009
On Jul 21, 2009, at 7:58 AM, William Kyngesburye wrote:
> I don't think it can - it needs Wxwidgets. It's a wxwidgets problem,
> so we can only work around it if/until wxwidgets is ever fixed (if
> that's even possible).
I meant rewrite this into wxPython so that this is no longer a
problem. Building on work by Glynn, I did a TclTk replacement for
xganim awhile back.
Michael
> Currently nviz and vdigit "avoid" this by a work around.
> On Jul 20, 2009, at 11:21 PM, Michael Barton wrote:
>> Maybe xganim needs to be changed to avoid this?
>> Michael
>> ____________________
>> C. Michael Barton, Professor of Anthropology
>> Director of Graduate Studies, School of Human Evolution & Social
>> Change
>> Director, Center for Social Dynamics & Complexity
>> Arizona State University
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> www: <www.public.asu.edu/~cmbarton>
>> On Jul 20, 2009, at 9:05 PM, William Kyngesburye wrote:
>>> I updated the makefile to strip 64bit flags on OSX. But I found
>>> another problem: it uses WXWIDGETSLIB for linking (it's only
>>> wxwidgets, not wxpython), and it includes universal flags,
>>> independently of however GRASS is configured.
>>> I've been compiling GRASS 7 with -arch i386 -arch x86_64, skipping
>>> PPC, and I'm sure many people will just opt for a "native" build
>>> (i386
>>> or ppc). So, the sources compile i386 (stripped of x86_64), but
>>> then
>>> tries to link i386 + ppc because of WXWIDGETSLIB.
>>> Nothing I can do about this, it's really a wxwidgets config bug.
>>> arch
>>> flags should not be a part of link flags, and the arch flags don't
>>> even appear in WXWIDGETSCXXFLAGS or WXWIDGETSCPPFLAGS where they
>>> should be.
>>> The workaround is to make sure to configure GRASS universal.
>>> WXWIDGETSLIB doesn't affect the wxpython modules, nviz and vdigit,
>>> wince they use a setup.py (where I have WXWIDGETSLIB ignored for
>>> OSX,
>>> though I'm not sure this is the right way).
>>> Maybe I can strip the arch flags out of WXWIDGETSLIB...
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
