[GRASS-dev] Re: [GRASS GIS] #697: v.surf.rst memory problems
trac at osgeo.org
Fri Jul 24 01:09:34 EDT 2009
Reporter: fpachecouy | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Changes (by helena):
* priority: major => normal
Comment:
Fernando - you are missing zcolumn for the values to be interpolated but
you are defining scolumn for the smoothing values.
I will change the priority to normal - the code should recognize the user
mistake and let him know that zcol is missing. If your data are 3D and the
value to interpolate is the z-coordinate then you need to define layer=0.
I have the code modification with -z flag instead of layer=0 for this
case, I just did not have time to submit.
Ticket URL: <http://trac.osgeo.org/grass/ticket/697#comment:1>
