[GRASS-dev] SWIG-Python lacking from install sequence in main
Makefile
Moritz Lennert
mlennert at club.worldonline.be
Mon Jul 27 11:15:35 EDT 2009
On 24/07/09 12:21, Glynn Clements wrote:
> Hamish wrote:
>> I am still having problems compiling swig/python on Debian/Lenny (current
>> stable) / 64bit with the latest GRASS 6.5svn.
>> the proj headers are missing from the $() Make rules:
>> "error: ogr_srs_api.h: No such file or directory"
>> it compiles in trunk ok.
> Note that using:
> vector_wrap_c_FLAGS = $(VECT_INC)
> proj_wrap_c_FLAGS = $(PROJINC) $(GDALCFLAGS)
> won't work in 6.4, as the build system doesn't use those variables.
> I suggest:
> EXTRA_INC = $(VECT_INC) $(PROJINC) $(GDALCFLAGS)
That solves it for me. Should this then be corrected for 65svn and
64_release ?
Moritz
