[GRASS-dev] SWIG-Python lacking from install sequence in main
Makefile
Glynn Clements
glynn at gclements.plus.com
Tue Jul 28 10:55:48 EDT 2009
Moritz Lennert wrote:
> >> I am still having problems compiling swig/python on Debian/Lenny (current
> >> stable) / 64bit with the latest GRASS 6.5svn.
> >> the proj headers are missing from the $() Make rules:
> >> "error: ogr_srs_api.h: No such file or directory"
> >> it compiles in trunk ok.
> > Note that using:
> > vector_wrap_c_FLAGS = $(VECT_INC)
> > proj_wrap_c_FLAGS = $(PROJINC) $(GDALCFLAGS)
> > won't work in 6.4, as the build system doesn't use those variables.
> > I suggest:
> > EXTRA_INC = $(VECT_INC) $(PROJINC) $(GDALCFLAGS)
> That solves it for me. Should this then be corrected for 65svn and
> 64_release ?
Yes.
