[GRASS-dev] SWIG-Python lacking from install sequence in main
Makefile
Moritz Lennert
mlennert at club.worldonline.be
Tue Jul 28 11:36:05 EDT 2009
On 28/07/09 16:55, Glynn Clements wrote:
> Moritz Lennert wrote:
>>>> I am still having problems compiling swig/python on Debian/Lenny (current
>>>> stable) / 64bit with the latest GRASS 6.5svn.
>>>> the proj headers are missing from the $() Make rules:
>>>> "error: ogr_srs_api.h: No such file or directory"
>>>> it compiles in trunk ok.
>>> Note that using:
>>> vector_wrap_c_FLAGS = $(VECT_INC)
>>> proj_wrap_c_FLAGS = $(PROJINC) $(GDALCFLAGS)
>>> won't work in 6.4, as the build system doesn't use those variables.
>>> I suggest:
>>> EXTRA_INC = $(VECT_INC) $(PROJINC) $(GDALCFLAGS)
>> That solves it for me. Should this then be corrected for 65svn and
>> 64_release ?
> Yes.
Done in r38529 and r38530.
Moritz
