[GRASS-dev] [GRASS GIS] #710: v.db.select: allow output to a file
trac at osgeo.org
Fri Jul 31 08:51:25 EDT 2009
Reporter: mlennert | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 6.5.0
Component: Vector | Version: unspecified
Keywords: v.db.select file | Platform: Unspecified
Cpu: Unspecified |
A file= parameter in v.db.select (and optionally db.select) would be nice
to allow direct export of table to csv from the GUI, without having to go
through the ogr trick. Currently you can use v.db.select with redirection
at the command line, but not in the GUI.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/710>
