[GRASS-dev] grass7 on WinGrass Multi.make deps
Colin Nielsen
colin.nielsen at gmail.com
Mon Jun 1 12:51:42 EDT 2009
> Hamish wrote:
>> > while reviewing & streamlining the WinGrass build instructions I notice
>> > a work-around is given for the grass 7 Make/Multi.make file which looks
>> > like it might be a bug. It is step 4 for building GRASS 7:
I've been in the field and computerless for the last month but I'm
back on task now. The work around was actually designed by Glynn last
January at my request, but you seem to be right that it is no longer
needed as I just had a successful compile without it. After looking at
the message again it may have been a mistake to include it since the
real problem was a version issue with MSys' make (3.79.1 vs 3.81).
Either way I'll remove it from the wiki since it is no longer needed.
Thanks for all the work including those bugfixes Hamish. My intention
by documenting them all was that someone would do that.
> not deleted it yet. The WinGrass build instructions are rapidly approaching
> "how to install Msys for OSGeo4W".
This is fine with me, the real goal for me was that if I can compile
grass on windows, than I can develop/compile my own grass modules for
my research, on windows. It also had the excellent side benefit of
providing wingrass bugfixing.
On that, the latest trunk update gave the following errors when
compiling, but otherwise seems to be running fine:
/src/trunk/scripts/r.colors.stddev
make: *** No rule to make target
`/src/trunk/dist.i686-pc-mingw32/scripts/r.colors.stddev.py', needed
by `script'. Stop.
/src/trunk/scripts/v.colors
/src/trunk/scripts/v.in.garmin
/src/trunk/scripts/v.in.gpsbabel
/src/trunk/scripts/v.out.gps
/src/trunk/visualization/nviz
-Colin
>> > https://trac.osgeo.org/grass/wiki/CompileOnWindows#Grass-7.0.svntrunk
> Glynn wrote:
>> Odd. I didn't need to make that change to build GRASS 7 on Windows.
>> OTOH, I don't see any problem with the alternative.
> Ok, on the assumption that it is no longer needed I've struck it out but
> still some funny business with tcltk NVIZ not launching from the wxGUI
> File menu. (uses the nviz.bat batch file; startup GUI pops up but when
> you hit Run just "process complete, 0 sec") I'm waiting on the next
> 6.4.0 binary build for all the spawn etc changes to filter through before
> spending much time on that though. (also various modes of g.gui from the
> command line act similarly, and as reported g.change.gui.py still isn't
> making it into the PATH.
> Hamish
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
