[GRASS-dev] Re: [GRASS GIS] #426: v.in.ogr: split long boundaries
trac at osgeo.org
Tue Jun 9 13:13:39 EDT 2009
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: major | Milestone: 6.5.0
Component: Vector | Version: unspecified
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by mmetz):
Fixed in trunk r37790.
Boundaries are split when cleaning, splitting is disabled when not
cleaning, no extra splitting flag. Additionally, boundaries are merged
later on, splitting is only needed to make Vect_break_lines() faster.
There is now a new cleaning tool in vector libs, Vect_merge_lines(). The
resulting vector should be topologically (c)leaner (less nodes and ready
to use with e.g. v.generalize) than grass6 imports.
Also new is the use of a temporary vector to reduce final coor file size
by a factor 2 to 5 for area imports.
Despite the new boundary merging and use of a temp vector, area imports
are considerably faster than with grass6, please test!
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/426#comment:11>
