[GRASS-dev] [GRASS GIS] #634: v.out.ogr error on Vista
GRASS GIS trac at osgeo.org
Tue Jun 9 14:51:53 EDT 2009
 Reporter:  cnielsen  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  major     |   Milestone:  6.4.0
Component:  default   |     Version:  unspecified
 Keywords:            |    Platform:  MSWindows Vista
      Cpu:  x86-32    |
 I'm not sure if this is just my own error or if its a larger issue of
 GDAL/OGR on Vista. I'm getting an error when trying to export a vector
 point file via v.out.ogr in the latest native wingrass (and on my own
 builds of develbranch_6 and trunk) on Vista-32.
 There's no message at all, just a regular windows box that says
 "v.out.ogr.exe has stopped working".
 I turned on DEBUG=5 but it isn't very informative either, the log is
 below. There wasn't a problem when I tried this on a winxp-64 machine.
 Please let me know what other information I should provide to help someone
 fix this.
 > v.out.ogr input=archsites type=point dsn=archsites
 D2/5: driver count = 26
 D2/5: driver 0/26 : ESRI Shapefile
 D2/5: driver 1/26 : MapInfo File
 D2/5: driver 4/26 : TIGER
 D2/5: driver 5/26 : S57
 D2/5: driver 6/26 : DGN
 D2/5: driver 9/26 : Memory
 D2/5: driver 10/26 : BNA
 D2/5: driver 11/26 : CSV
 D2/5: driver 12/26 : GML
 D2/5: driver 13/26 : GPX
 D2/5: driver 14/26 : KML
 D2/5: driver 15/26 : GeoJSON
 D2/5: driver 16/26 : Interlis 1
 D2/5: driver 17/26 : Interlis 2
 D2/5: driver 18/26 : GMT
 D2/5: driver 19/26 : SQLite
 D2/5: driver 20/26 : ODBC
 D2/5: driver 23/26 : PostgreSQL
 D2/5: driver 24/26 : MySQL
 D2/5: all drivers:
 ESRI_Shapefile,MapInfo_File,TIGER,S57,DGN,Memory,BNA,CSV,GML,GPX,KML,GeoJSON,Interlis_1,Interlis_2,GMT,SQLite,ODBC,PostgreSQL,MySQL,
 D1/5: Vect_open_old(): name = archsites mapset= PERMANENT update = 0
 D1/5: Vect_set_thresh(): thresh = 0.000000
 D3/5: dig_init_plus()
 D1/5: dig_spidx_init()
 D3/5: dig_cidx_init()
 D1/5: open format file: 'PERMANENT/vector/archsites/frmt'
 D1/5: Vector format: 0 (native)
 D1/5: Vect__read_head(): vector = archsites at PERMANENT
 D1/5: Level request = 2
 D1/5: Vect_open_topo(): name = archsites mapset= PERMANENT
 D1/5: get coor info: C:/Users/Llamo/Documents/GIS
 DataBase/Spearfish60/PERMANENT/vector/archsites/coor
 D1/5: Info->size = 739, Info->mtime = 1113226004
 D2/5: Topo header: file version 5.0 , supported from GRASS version 5.0
 D2/5:   byte order 0
 D2/5:   header size 142
 D2/5:   with_z 0
 D2/5:   coor size 739
 D1/5: Topo head: coor size = 739, coor mtime = 1995283852
 D1/5: dig_load_plus()
 D2/5:   byte order 0
 D2/5:   with_z 0
 D2/5:   coor size 739
 D3/5: dig_Rd_P_node()
 D3/5: dig_node_alloc_line(): add = 1
 D3/5: dig_Rd_P_line()
 D5/5:     line type  1 -> 1
 D3/5: dig_alloc_isle():
 D2/5: Vect_cidx_open(): name = archsites mapset= PERMANENT
 D3/5: dig_read_cidx()
 D3/5: Cidx header: file version 5.0 , supported from GRASS version 5.0
 D3/5:   byte order 0
 D3/5:   header size 9
 D1/5: V1_open_old_nat(): name = archsites mapset = PERMANENT
 D2/5: Coor header: file version 5.1 , supported from GRASS version 5.1
 D2/5:   byte order 0
 D2/5:   with_z 0
 D2/5:   coor size 739
 D1/5: coor size in head = 739, real coor file size= 739
 D2/5: dig_file_load ()
 D2/5:   requested mode = 2
 D2/5:   size = 739
 D2/5:   file was not loaded to the memory
 D1/5: Vect_open_old(): vector opened on level 2
 D1/5: Vect_read_dblinks(): map = archsites, mapset = PERMANENT
 D3/5: Searching for FID column in OGR DB
 D1/5: dbln file: C:/Users/Llamo/Documents/GIS
 DataBase/Spearfish60/PERMANENT/vector/archsites/dbln
 D1/5: dbln: 1 archsites cat $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
 D3/5: Field number <1>, name <(null)>
 D3/5: Vect_check_dblink: field 1
 D1/5: field = 1 name = (null), table = archsites, key = cat, database
 = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/, driver = dbf
 D1/5: Dblinks read
 D1/5: Vect_Rewind(): name = archsites
 D2/5: G__read_Cell_head
 D2/5: G__read_Cell_head_array
 D3/5: region item: proj:       1
 D3/5: region item: zone:       13
 D3/5: region item: north:      4928010
 D3/5: region item: south:      4913700
 D3/5: region item: east:       609000
 D3/5: region item: west:       589980
 D3/5: region item: cols:       634
 D3/5: region item: rows:       477
 D3/5: region item: e-w resol:  30
 D3/5: region item: n-s resol:  30
 D3/5: region item: top:        1
 D3/5: region item: bottom:     0
 D3/5: region item: cols3:      634
 D3/5: region item: rows3:      477
 D3/5: region item: depths:     1
 D3/5: region item: e-w resol3: 30
 D3/5: region item: n-s resol3: 30
 D3/5: region item: t-b resol:  1
 D2/5: driver count = 52
 D2/5: driver 0 : ESRI Shapefile
 D2/5:  -> driver = 0
 D2/5: driver 1 : MapInfo File
 D2/5: driver 2 : UK .NTF
 D2/5: driver 3 : SDTS
 D2/5: driver 4 : TIGER
 D2/5: driver 5 : S57
 D2/5: driver 6 : DGN
 D2/5: driver 7 : VRT
 D2/5: driver 8 : REC
 D2/5: driver 9 : Memory
 D2/5: driver 10 : BNA
 D2/5: driver 11 : CSV
 D2/5: driver 12 : GML
 D2/5: driver 13 : GPX
 D2/5: driver 14 : KML
 D2/5: driver 15 : GeoJSON
 D2/5: driver 16 : Interlis 1
 D2/5: driver 17 : Interlis 2
 D2/5: driver 18 : GMT
 D2/5: driver 19 : SQLite
 D2/5: driver 20 : ODBC
 D2/5: driver 21 : PGeo
 D2/5: driver 22 : OGDI
 D2/5: driver 23 : PostgreSQL
 D2/5: driver 24 : MySQL
 D2/5: driver 25 : AVCBin
 D2/5: driver 26 : ESRI Shapefile
 D2/5:  -> driver = 26
 D2/5: driver 27 : MapInfo File
 D2/5: driver 28 : UK .NTF
 D2/5: driver 29 : SDTS
 D2/5: driver 30 : TIGER
 D2/5: driver 31 : S57
 D2/5: driver 32 : DGN
 D2/5: driver 33 : VRT
 D2/5: driver 34 : REC
 D2/5: driver 35 : Memory
 D2/5: driver 36 : BNA
 D2/5: driver 37 : CSV
 D2/5: driver 38 : GML
 D2/5: driver 39 : GPX
 D2/5: driver 40 : KML
 D2/5: driver 41 : GeoJSON
 D2/5: driver 42 : Interlis 1
 D2/5: driver 43 : Interlis 2
 D2/5: driver 44 : GMT
 D2/5: driver 45 : SQLite
 D2/5: driver 46 : ODBC
 D2/5: driver 47 : PGeo
 D2/5: driver 48 : OGDI
 D2/5: driver 49 : PostgreSQL
 D2/5: driver 50 : MySQL
 D2/5: driver 51 : AVCBin
Ticket URL: <http://trac.osgeo.org/grass/ticket/634>
