[GRASS-dev] Re: [GRASS GIS] #629: WinGRASS: spaces in pathnames
GRASS GIS trac at osgeo.org
Wed Jun 10 11:12:54 EDT 2009
  Reporter:  hamish        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  6.4.0 RCs
Resolution:                |    Keywords:  wingrass, msys
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by cnielsen):
 Bad news about the spaces...
 In the new wingrass release (6.4.0rc5 later today) I've updated msys.bat
 to:
 ...{{{ start "MSYS 1.0" "%WD%rxvt" }}}...
 I can't think of a way the "dir /x" fix could be used within the installer
 to adjust things to the 8.3 path names, but if someone else can I'll
 implement it.
 The empty grass dir is a mount point for the install directory and allows
 the grass with msys shortcuts to be executed with {{{msys.bat
 /grass/bin/grass64 -wxpython}}} etc. I tried quotes in the fstab file but
 it doesn't work, which means that the grass with msys shortcuts won't work
 either if installed in a path with spaces.
Ticket URL: <http://trac.osgeo.org/grass/ticket/629#comment:7>
