[GRASS-dev] Re: [GRASS GIS] #629: WinGRASS: spaces in pathnames
trac at osgeo.org
Wed Jun 10 23:19:24 EDT 2009
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass, msys
Platform: MSWindows XP | Cpu: x86-32
Comment (by hamish):
Replying to [comment:7 cnielsen]:
> I can't think of a way the "dir /x" fix could be used within
> the installer to adjust things to the 8.3 path names, but if
> someone else can I'll implement it.
> The empty grass dir is a mount point for the install
> directory
yeah I realized that after posting,
> and allows the grass with msys shortcuts to
> be executed with {{{msys.bat /grass/bin/grass64 -wxpython}}}
> etc.
I don't really understand that.
> I tried quotes in the fstab file but it doesn't work,
> which means that the grass with msys shortcuts won't work
> either if installed in a path with spaces.
it is the fstab file that needs the PROGRA~1 style because it uses
whitespace as the column deliminator and has no quoting ability.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/629#comment:8>
