[GRASS-dev] r.in.gdal problems
Markus GRASS
markus.metz.giswork at googlemail.com
Wed Jun 10 16:10:03 EDT 2009
Laura Toma wrote:
> Hi,
> I imported a large SRTM grid with r.in.gdal; when starting grass64
> with this location there is an error.
> Some part of Grass seems to work despite this error, except d.rast
> shows a blank screen. The east and west (see below) have the same
> value, except E/W. Could this cause troubles?
Both values are smaller than 180, so they should not give problems in a
ll projection. What could give problems is the ew resolution of
0:00:00.000007 which is an amazing resolution for a DEM covering the
whole world, especially SRTM (native resolution is 0:00:03 for the world
coverage dataset). Should that not be the same like the ns resolution,
0:00:03? Maybe something went wrong with r.in.gdal? Does gdalinfo report
the same ew resolution? The resolution of 0:00:00.000007 can cause the
"divide by zero" error when trying to set the current region and/or
display parameters. A workaround may be to start grass in text mode and
set the region resolution to 0:00:03, both ns and ew, then start the
gui. Or manually edit the WIND and DEFAULT_WIND files before launching
grass.
Markus M
> GRASS 6.4.0RC4
> (northamericaSRTM3):~/gis/DATA/SRTM/SRTM-V2-frome0srp01u.ecs.nasa.gov/SRTM3/north_america
> > Error in startup script: divide by zero
> while executing
> "expr round($parts(w)/$parts(ewres))*$parts(ewres)"
> (procedure "MapCanvas::zoom_gregion" line 17)
> invoked from within
> "MapCanvas::zoom_gregion $mon"
> (procedure "MapCanvas::create" line 40)
> invoked from within
> "MapCanvas::create"
> (procedure "Gm::startmon" line 11)
> invoked from within
> "Gm::startmon"
> (procedure "Gm::create" line 79)
> invoked from within
> "Gm::create"
> (procedure "main" line 30)
> invoked from within
> "main $argc $argv"
> (file "/usr/local/grass/grass-6.4.0RC4/etc/gm/gm.tcl" line 566)
> GRASS 6.4.0RC4
> > g.region -p
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 61:00:01.5N
> south: 9:59:58.5N
> west: 179:59:58.5E
> east: 179:59:58.5W
> nsres: 0:00:03
> ewres: 0:00:00.000007
> rows: 61201
> cols: 432001
> cells: 26438893201
> GRASS 6.4.0RC4
> > r.info na_mosaic
> | Layer: na_mosaic Date: Tue Jun 9 21:54:39
> 2009 |
> | Mapset: PERMANENT Login of Creator:
> ltoma |
> | Location:
> northamericaSRTM3 |
> | DataBase:
> /mnt/research/gis/DATA/grassdb/ |
> | Title: ( na_mosaic
> | Timestamp:
> none |
> | Type of Map: raster Number of Categories:
> 5573 |
> | Data Type:
> CELL |
> | Rows:
> 61201 |
> | Columns:
> 432001 |
> | Total Cells:
> 26438893201 |
> | Projection:
> Latitude-Longitude |
> | N: 61:00:01.5N S: 9:59:58.5N Res:
> 0:00:03 |
> | E: 179:59:58.5W W: 179:59:58.5E Res:
> 0:00:00.000007 |
> | Range of data: min = -291 max =
> 5573 |
> | Data
> Description: |
> | generated by
> r.in.gdal |
> Comments:
> | r.in.gdal input="na_mosaic.vrt"
> output="na_mosaic" |
> -Laura_______________________________________________
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
