[GRASS-dev] r.in.gdal problems
Laura Toma ltoma at bowdoin.edu
Wed Jun 10 16:45:31 EDT 2009
Markus,
Here is what the cellhd contains (it seems correct).
proj:       3
zone:       0
north:      61:00:01.5N
south:      9:59:58.5N
east:       179:59:58.5W
west:       179:59:58.5E
cols:       432001
rows:       61201
e-w resol:  0:00:03
n-s resol:  0:00:03
format:     3
compressed: 1
  but r.info gives:
    Projection: Latitude-
Longitude                                      |
  |            N: 61:00:01.5N    S: 9:59:58.5N   Res:
0:00:03                  |
  |            E: 179:59:58.5W    W: 179:59:58.5E   Res:
0:00:00.000007        |
so for some reason the ewres is messed up.
Here is the tif file that I used as input in r.in.gdal:
gdalinfo na_mosaic.tif
Driver: GTiff/GeoTIFF
Files: na_mosaic.tif
Size is 432001, 61201
Coordinate System is:
GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.2572235630016,
             AUTHORITY["EPSG","7030"]],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0],
     UNIT["degree",0.0174532925199433],
     AUTHORITY["EPSG","4326"]]
Origin = (-180.000416666666666,61.000416666666666)
Pixel Size = (0.000833333333333,-0.000833333333333)
Metadata:
   AREA_OR_POINT=Area
Image Structure Metadata:
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-180.0004167,  61.0004167) (180d 0'1.50"W, 61d 0'1.50"N)
Lower Left  (-180.0004167,   9.9995833) (180d 0'1.50"W,  9d59'58.50"N)
Upper Right ( 180.0004167,  61.0004167) (180d 0'1.50"E, 61d 0'1.50"N)
Lower Right ( 180.0004167,   9.9995833) (180d 0'1.50"E,  9d59'58.50"N)
Center      (  -0.0000000,  35.5000000) (  0d 0'0.00"W, 35d30'0.00"N)
Band 1 Block=432001x1 Type=Int16, ColorInterp=Gray
   NoData Value=-32768
[ltoma at dover:~/gis/DATA/SRTM/SRTM-V2-frome0srp01u.ecs.nasa.gov/SRTM3/
north_america]$
On Jun 10, 2009, at 4:10 PM, Markus GRASS wrote:
> Laura Toma wrote:
>> Hi,
>> I imported a large SRTM grid with r.in.gdal;  when starting grass64
>> with this location there is an error.
>> Some part of Grass seems to work despite this error, except d.rast
>> shows a blank screen.  The east and west (see below)  have the same
>> value, except E/W. Could this cause troubles?
> Both values are smaller than 180, so they should not give problems
> in a
> ll projection. What could give problems is the ew resolution of
> 0:00:00.000007 which is an amazing resolution for a DEM covering the
> whole world, especially SRTM (native resolution is 0:00:03 for the
> world
> coverage dataset). Should that not be the same like the ns resolution,
> 0:00:03? Maybe something went wrong with r.in.gdal? Does gdalinfo
> report
> the same ew resolution? The resolution of 0:00:00.000007 can cause the
> "divide by zero" error when trying to set the current region and/or
> display parameters. A workaround may be to start grass in text mode
> and
> set the region resolution to 0:00:03, both ns and ew, then start the
> gui. Or manually edit the WIND and DEFAULT_WIND files before launching
> grass.
> Markus M
>> GRASS 6.4.0RC4
>> (northamericaSRTM3):~/gis/DATA/SRTM/SRTM-V2-
>> frome0srp01u.ecs.nasa.gov/SRTM3/north_america
>>> Error in startup script: divide by zero
>>    while executing
>> "expr round($parts(w)/$parts(ewres))*$parts(ewres)"
>>    (procedure "MapCanvas::zoom_gregion" line 17)
>>    invoked from within
>> "MapCanvas::zoom_gregion $mon"
>>    (procedure "MapCanvas::create" line 40)
>>    invoked from within
>> "MapCanvas::create"
>>    (procedure "Gm::startmon" line 11)
>>    invoked from within
>> "Gm::startmon"
>>    (procedure "Gm::create" line 79)
>>    invoked from within
>> "Gm::create"
>>    (procedure "main" line 30)
>>    invoked from within
>> "main $argc $argv"
>>    (file "/usr/local/grass/grass-6.4.0RC4/etc/gm/gm.tcl" line 566)
>> GRASS 6.4.0RC4
>>> g.region -p
>> projection: 3 (Latitude-Longitude)
>> zone:       0
>> datum:      wgs84
>> ellipsoid:  wgs84
>> north:      61:00:01.5N
>> south:      9:59:58.5N
>> west:       179:59:58.5E
>> east:       179:59:58.5W
>> nsres:      0:00:03
>> ewres:      0:00:00.000007
>> rows:       61201
>> cols:       432001
>> cells:      26438893201
>> GRASS 6.4.0RC4
>>> r.info na_mosaic
>> | Layer:    na_mosaic                      Date: Tue Jun  9 21:54:39
>> 2009    |
>> | Mapset:   PERMANENT                      Login of Creator:
>> ltoma           |
>> | Location:
>> northamericaSRTM3                                                |
>> | DataBase:
>> /mnt/research/gis/DATA/grassdb/                                  |
>> | Title:     ( na_mosaic
>> | Timestamp:
>> none                                                            |
>> |   Type of Map:  raster               Number of Categories:
>> 5573            |
>> |   Data Type:
>> CELL                                                       |
>> |   Rows:
>> 61201                                                      |
>> |   Columns:
>> 432001                                                     |
>> |   Total Cells:
>> 26438893201                                                |
>> |        Projection:
>> Latitude-Longitude                                      |
>> 0:00:03                  |
>> 0:00:00.000007        |
>> |   Range of data:    min = -291  max =
>> 5573                                 |
>> |   Data
>> Description:                                                        |
>> |    generated by
>> r.in.gdal                                                  |
>> Comments:
>> |    r.in.gdal input="na_mosaic.vrt"
>> output="na_mosaic"                      |
>> -Laura_______________________________________________
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
