[GRASS-dev] Re: [GRASS GIS] #642: Refresh button / auto refresh
button for Attribute Table viewer while using wxvdigit
trac at osgeo.org
Mon Jun 15 14:10:38 EDT 2009
#642: Refresh button / auto refresh button for Attribute Table viewer while using
wxvdigit
Reporter: stevensj | Owner: martinl
Type: enhancement | Status: assigned
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords: v.digit refresh
Platform: Unspecified | Cpu: Unspecified
Changes (by martinl):
* status: new => assigned
* owner: grass-dev at lists.osgeo.org => martinl
* cc: martinl (removed)
* cc: grass-dev at lists.osgeo.org (added)
Comment:
Replying to [comment:1 martinl]:
> > It would be good if the attribute table could be refreshed, either
automatically when the attribute table chance, or with a refresh button on
the tab with the data view.
> See above. Your wish to refresh attribute list when digitizing (eg.
adding new feature) seems reasonable to me. I changed milestone to 6.5
since there is no change to get this feature to 6.4.0.
Done in r37888 (trunk) and r37889 (devbr6). Note that currently data are
reloaded (which is very time consuming task for large attribute tables).
Ideally should be added/removed only given row from the list (TODO).
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/642#comment:2>
