[GRASS-dev] Re: [GRASS GIS] #570: startup problem with standalone GRASS install
GRASS GIS trac at osgeo.org
Wed Jun 17 05:34:41 EDT 2009
  Reporter:  timmie        |       Owner:  timmie
      Type:  defect        |      Status:  reopened
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  svn-develbranch6
Resolution:                |    Keywords:  wingrass, python
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by timmie):
 Replying to [comment:24 hamish]:
 > Replying to [comment:23 timmie]:
 > > %GRASS_PYTHON% => I thought that this one is set at runtime by GRASS.
 > If it is working as designed it should respect the value you give for
 GRASS_PYTHON if it is already set; it should only set automatically if
 unset.. if you launch grass with ' -text' and type "set" at the command
 prompt you should be able to see/confirm how it is set.
 I started GRASS through the Start Menu -> GRASS Command Line
 then did:
 #. enter a location
 #. set > myvars.txt
 in the file myvars.txt GRASS_PYTHON is nowhere to be found.
 > Even if it is still not working we have cleaned up all(?) of the
 GRASS_PYTHON calls in grass during the course of this > bug & so are much
 closer than we were when we started.
 Thanks for the positive words and patience you always send across.
 > > I do not know anymore, what to do.
 > I guess you have to use the Tcl/Tk GUI or command prompt until we can
 figure out the solution. Even if it is still not working we have cleaned
 up all(?) of the GRASS_PYTHON calls in grass during the course of this bug
 & so are much closer than we were when we started.
 > Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/570#comment:25>
