[GRASS-dev] [GRASS GIS] #654: g.proj -c fails with ERROR: region for current mapset is not set run "g.region"
GRASS GIS trac at osgeo.org
Wed Jun 17 07:21:02 EDT 2009
"g.region"
 Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  6.4.0
Component:  default   |     Version:  6.4.0 RCs
 Keywords:  g.proj    |    Platform:  All
      Cpu:  All       |
 As reported on grass-user
  g.proj -c georef=swilAlphaTIFF.tif location=tset
 fails with recent builds. I can reproduce on linux.
 I traced this back to r37726 where wind_format.c's format_double()
 uses G_projection() which wants to check the projection type (and that
 hasn't been created yet).
 I think the solution is to create a new lib fn
  char *G_format_number(double value, int dp);
 so modules don't have to lie to G_format_northing() about their projection
 type in order to get numeric output from lat/lon locations. then we can
 get rid of G_projection() from format_double().
 Either that or finally implement GRASS_DMS_STYLE variable and temporarily
 set that to numeric degree style.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/654>
