[GRASS-dev] Re: [GRASS GIS] #654: g.proj -c fails with ERROR:
region for current mapset is not set run "g.region"
trac at osgeo.org
Wed Jun 17 07:32:22 EDT 2009
#654: g.proj -c fails with ERROR: region for current mapset is not set run
"g.region"
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords: g.proj
Platform: All | Cpu: All
Comment (by hamish):
Replying to [ticket:654 hamish]:
> wind_format.c's format_double() uses G_projection() which wants
> to check the projection type (and that hasn't been created yet).
actually it has in a way,
the top two lines of PERMANENT/DEFAULT_WIND are written:
proj: 99
zone: 0
I'm not really sure if that helps though.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/654#comment:1>
