[GRASS-dev] Re: [GRASS GIS] #654: g.proj -c fails with ERROR:
region for current mapset is not set run "g.region"
trac at osgeo.org
Wed Jun 17 09:52:32 EDT 2009
#654: g.proj -c fails with ERROR: region for current mapset is not set run
"g.region"
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords: g.proj
Platform: All | Cpu: All
Comment (by hamish):
> I think the solution is to create a new lib fn
> char *G_format_number(double value, int dp);
better, path of least change: allow G_format_northing() etc to accept "-1"
for projection type which in this instance can mean use "%.15g"
independent of the projection.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/654#comment:2>
