[GRASS-dev] Re: [GRASS GIS] #654: g.proj -c fails with ERROR:
region for current mapset is not set run "g.region"
trac at osgeo.org
Thu Jun 18 03:31:53 EDT 2009
#654: g.proj -c fails with ERROR: region for current mapset is not set run
"g.region"
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords: g.proj
Platform: All | Cpu: All
Comment (by hamish):
patch attached, but that's the easy part. It turns out a lot of modules
are already using proj == -1 or similar to fool G_format_*() into
outputting numerical output instead of DMS for certain tasks. i.e. this
patch, or something like it, is long overdue.
need to audit all of the custom workarounds before applying..
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/654#comment:3>
