[GRASS-dev] terminology issues in grass7
roger at spinn.net
roger at spinn.net
Wed Jun 17 13:46:48 EDT 2009
Moritz Lennert writes:
> On 17/06/09 14:58, Roger Miller wrote:
>> The "layer=" feature of the commands seems to me to be largely if not
>> entirely superfluous. The function that it performs can be duplicated
>> by "where="
> This would mean mixing different types of objects into the same layer and
> thus the same attribute table. I.e. in the field boundaries = roads
> example, you would have to use the same table for the centroids
> characterising the fields and for the boundary line which (also)
> represents a road.
> Not very clean in my understanding...
>> and/or "catlist=".
> But this supposes that the user knows the cats, which often is not the
> case, and it eliminates the possibility of linking different types of
> objects to different attribute tables.
> So, neither of these would really replace the current layer feature.
So to continue the usage discussion...
I agree that the first case would not be very clean. The problem in the
example is that it uses one data set for two different purposes, which I
would generally discourage; it will usually lead to other problems. If I
understand the example correctly, then you might get the effect you need by
drawing the boundaries and the areas with different d.vect commands, using
the "type=" capability.
In the second case, GRASS provides several ways for the user to find the
cats. I agree, it would be impossible to associate one vector "file" with
more than one attribute table without the "layer=" capability. Again, that
is a practice I discourage because of the data management problems it is
likely to create. I would merge those attribute tables or I would copy the
vector "file" to a second file and associate the second file with the second
attribute table.
GRASS offers a lot of ways to generate visual layers in a map without using
the "layer=" capability. Keeping the capability gives users more options,
so I wouldn't argue that it should be removed, just that it should be
renamed. I'm not a teacher, but it seems to me to be (in addition to the
problem with the term overlapping in applications) a problem with clarity.
Are students going to understand that visual layers can be created with i.e.
"where=" and that they don't have to use "layer=" to get the layered visual
they need?
If we are to use the term "layer" it would be better to restrict its usage
to refer to a visual object, and to use a different term to refer to
database features that may or may not be used to generate the visual.
Roger
