[GRASS-dev] Re: [SoC] [Report #4] Kriging with GRASS and R:
v.autokrige port to wxPython and more
Martin Landa
landa.martin at gmail.com
Fri Jun 19 11:07:52 EDT 2009
2009/6/19 Michael Barton <michael.barton at asu.edu>:
> Checked the Wiki site. For the vector selection choicebox, use the
> Select.select class and method we've already created. It's more flexible,
> will show multiple mapsets in a tree organization, and will save you code.
I have already suggested to Anne to use standard wxGUI widgets located
in gselect module. Probably most of them need to be updated, e.g. in
this case to show only vector maps which contains some points.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
